LTM load balancing Exchange 2010 OWA
I used iapp - for setting up LB of OWA & other exchange services with 2 Exchange 2010 nodes.
the problem is
when user access the F5 virtual server as , F5 displays its own logon server (as per my config) and after user is successfully logged in, user is redirected to member node
how to retain the user in the same domain as
- Faruk_AYDIN
Altostratus
external URL must be set on the Exchange side.
the details are here: https://docs.microsoft.com/en-us/previous-versions/office/exchange-server-2010/bb310763(v=exchg.141) - youssef1
Cumulonimbus
Faruk is right, the problem is in exchange side.
I already manage this kind of problem:
https://devcentral.f5.com/questions/internal-cas-server-hostname-after-f5-apm-login-61183
Can you please check the post above and tell me if it help you.
Regards
- Anand_Prabhu
Thank you all for replying to my query.
The issue is resolved after choosing SSL Bridging option in F5. SSL is offloaded in F5 but I must choose this "SSL Bridging" option, because another SSL is also installed in CAS Server.
I wrote an article here to help someone who may face similar issue.
http://itadminguide.com/issue-of-f5-redirecting-exchange-owa-web-address-to-direct-cas-server-name/
