LTM ip forwarding for outbound traffic over two gateways
Hi, I configured a LTM in my lab as a forward proxy for outbound traffic. The vs uses a gateway pool which contains two gateways (linux based in ip forwarding mode). This pool is also the default gateway for the BIG-IP itself. I configured on the pool "action on service down" and set it to "reselect". The problem is when I open a wget session on a client that uses the vs for downloading an iso file from the internet the session is just ready as long as the specific gateway pool member is available. If the specific pool member goes down for some reason the session will be broken. How is it possible to configure LTM in load balance per packet mode? Thank you, bb
- nitass
Employee
have you tried stateless forwarding virtual server (i.e. immediate idle timeout)?
sol7595: Overview of IP forwarding virtual servers
http://support.f5.com/kb/en-us/solutions/public/7000/500/sol7595.html - Andrea_Arquint
with stateless vs you cannot assign a tcp profile. I need to configure performance (L4) min. to assigen a pool of gateways to the wildcard virtual. So there must be another approach but I still don't know how to do it.
