LTM health monitor question
Hello Guys, I had a health monitor request from application team to make sure that the pool members were marked up if it was any 1,2,3,4 status codes. So in the receive string I used
HTTP/1.(0|1) (1|2|3|4)
But now the requirement is to exclude 404, ie if the pool members returns 404 it should be marked down.
So I came up with this - HTTP/1.[01] ([123]0[0-6]|401|402|403|[4]0[5-51])
Will the above work or can anyone suggest more elegant way for this receive string.
Thank you.
you can configure the "Receive Disable String".
This setting works like Receive String, except that the system marks the node or pool member disabled when its response matches Receive Disable String but not Receive String. To use this setting, you must specify both Receive Disable String and Receive String.
- Andy_McGrath
Cumulonimbus
Try this, it works on https://regex101.com/ but not sure it the regex in F5 allows for negative/inverse matching
(?!404)HTTP\/1.(0|1) (?!404)(1|2|3|4)The ordering is important the
needs to be in front of any positive match like(?!404)(1|2|3|4)You also might not need the escape character before the
so it would be:/HTTP/1.(0|1) (?!404)(1|2|3|4)
