JRahm's avatar
JRahm
Icon for Admin rankAdmin
Oct 02, 2014
LTM doing routing - forwarding packets between vlans
On behalf of user Paolo:
Hi so what is happening is my ltm ( all og them ) is doing unexpectedly ( by me ) routing:
[LB:Active:Changes Pending] config  tcpdump -i any  host 173.194.116.100
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on any, link-type EN10MB (Ethernet), capture size 96 bytes
^[[A11:16:03.615517 IP 10.117.161.131.53931 > 173.194.116.100.http: S 2027984805:2027984805(0) win 8192
11:16:03.615612 IP 10.117.61.12.53931 > 173.194.116.100.http: S 2027984805:2027984805(0) win 8192
As you can see the packets hit the LB gets to the external interface snatted and then gets out...
If that can be of help i have no forwarding VIPS and i try to lock the sel ips in the internal vlan to none.
Ideas ?
what strikes me is this
net.ipv4.ip_forward = 0
  • do you have a default snat on the system?
    YOu can get greater detail of the capture by using:
    tcpdump -ni 0.0:nnn host 173.194.116.100 -s0
