LTM Certificates Installation, without a key
I am having consistent issues with our internal CA admins who continually issue certificate without keys. Can the LTM's support a certificate without a key or is it required to have an associating key with the certificate in our LTM's?
- Kevin_Stewart
Employee
Well two things:
You absolutely need the private key in the LTM SSL config.
It's highly unlikely (let's say cryptographically impossible) that the CA admins are issuing PKI certs without keys. It's more plausible that they're issuing certs and just not giving you and/or exporting the private key.
- Mike_Sullivan_2
You can generate your own signing request and have your PKI admins sign it. That way you'll have the private keys on the box.
Cheers, Mike
