looking for help to tweak iRule
Folks, We have an iRule which looks at the HTTP request and does some work based on that request.
Here is the extract: if { [HTTP::host] contains "domainname.com"}
and then do this do that. I want to add one more clause in the same statement saying if HTTP::host contains domainname.com and the requests is on SSL.
How can I do that?
Thanks, N.
- Faruk_AYDIN
Altostratus
use one of the followings:
First:if { [HTTP::host] contains "domainname.com" && [SSL::mode] == 0 }Second:
if { [HTTP::host] contains "domainname.com" && [TCP::local_port] == 443 } - stan_piron
Cumulonimbus
the question is WHY?
when you configure a virtual server with an irule, you may know if the server is SSL or not.
I tried the SSL::mode command and it don't work if CLIENTSSL or SERVERSSL profiles are not assigned to the VS.
