Waynengi's avatar
Waynengi
Jan 06, 2018
Does particular irule need to be tweaked?
Created an irule below but it only seems to work for lowercase not uppercase. Do I have to add another line or can it be tweaked to catch anything? "coordinatororporttype"
when HTTP_REQUEST { if { [string tolower [HTTP::uri]] contains "/wls-wsat/coordinatorporttype" } { log local0. "matched URI [HTTP::uri]" drop } }
  • it should also work for the uppercase. can you try to add logging before the if sentence?
    e.g.
    log local0. "URI is [HTTP::uri]"
    • nitass's avatar
      nitass
      e.g.
          drop
    • Waynengi's avatar
      Waynengi
      I'll do some testing. I take that will show in the log file of what's happening. Right?
    e.g.
    • nitass_89166's avatar
      nitass_89166
      Icon for Noctilucent rankNoctilucent
      e.g.
          drop
    • Waynengi's avatar
      Waynengi
  • oguzy's avatar
    oguzy
    You check the ltm log using "tail -f" parameter, right?
