Daniel_Ao_10370's avatar
Daniel_Ao_10370
Nov 20, 2009
Long Live HTTPS session Load balance
I would like to implement per-message (instead of per session) load balance to backend servers in long live HTTPS session. Is it possible to do that?
  • hoolio's avatar
    hoolio
    If the app doesn't require session persistence, you could disable persistence and add a OneConnect profile to the VIP.
    Aaron
  • Here is some information about OneConnect
    http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=114
    http://devcentral.f5.com/Wiki/default.aspx/AdvDesignConfig/OneConnect.html
    https://support.f5.com/kb/en-us/solutions/public/7000/200/sol7208.html (Requires ask.f5.com login)
    I hope this helps
    Thanks,
    Bhattman
