oddarnep_40030's avatar
oddarnep_40030
Jul 02, 2012
Logon form problem
I have been testing the Big-IP APM/VE in a lab for several days.
I have come across a "problem" with a 3rd party OTP solution called Securenvoy.
The program itself runs a radius server.
My question is:
Is it possible to create 3 fields on a logon page. Username, Password, Passcode
Then have the Big-IP put together the Password+Passcode and send this as the password to the radius?
Securenvoy radius is expecting the password+passcode to come in password "field".
Hope this made any sense.
  • Richard__Harlan's avatar
    Richard__Harlan
    Historic F5 Account
    In the VPE if you click on the logon page you should be able to add a third field to the logon page. Then you should be able to create a iRule to concat the two variables and place it in the password session
    ACCESS::session data get [-sid ] [-secure]
    ACCESS::session data set [-sid ] [-secure] []
    You should have to use the secure flag to read and write the password field.
  • You won't even need an iRule, you can use a Variable Assign in the VPE:
    session.logon.last.password = expr { "[mcget -secure {session.logon.last.password}][mcget {session.logon.last.}]" }
