Ah_Fat_2262
Mar 30, 2012Logging Of Traffic Logs For HTTP Connection
I would like to log the traffic log of a certain IP HTTP connection. Can iRule achieve that?. If yes, please advice.
Thks and Rgds
- Ah_Fat_2262
I have done some check on the F5 DevCentral forum (https://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/8888/showtab/groupforums/Default.aspx) and they mentioned that it can be done via the iRule. Please refer to the below for the script to log the HTTP connection.
HTTP logger rule:
set the URL here, log it on the response
set url [HTTP::header Host][HTTP::uri]
set vip [IP::local_addr]:[TCP::local_port]
when HTTP_RESPONSE {
set client [IP::client_addr]:[TCP::client_port]
set node [IP::server_addr]:[TCP::server_port]
set nodeResp [HTTP::status]
log connection info
log local0.info "Client: $client -> VIP:$vip$url -> Node: $node with response $nodeResp"
Thus, I would like to check with you that do I need to input any values to the portion in bold & italic or just leave it as default?
On top of that, if all these logs are to be send to the remote syslog server,
1) Will F5 auto log to the logs to remote server? or 2) Do I still need to configure the syslog-ng to send the log to the remote server? after I have configure the remote syslog server to the F5.
Thks and Rgds - hoolio
Hi Ah Fat,
If you're on 10.1 or higher, I suggest using High Speed Logging to send the logging directly from TMM without logging locally or going through syslog-ng. HSL should be a lot more efficient. For details check the HSL wiki page:
https://devcentral.f5.com/wiki/iRules.hsl.ashx
And here are a couple of examples:
https://devcentral.f5.com/wiki/iRules.FormattedLoggingForW3c.ashx
https://devcentral.f5.com/wiki/iRules.Log-Tcp-And-Http-Request-Response-Info-Remotely.ashx
Aaron - Ah_Fat_2262
Hi Aaron,
The examples seem very complicated. Is there anything more simpler?....I am just a beginner for F5 appliance.
Rgds - hoolio
You could use the second example exactly as it is. Or if you want to log just on the HTTP response you could use this:when RULE_INIT { Save the name of the BIG-IP set static::bigip [info hostname] Set the log facility Ex: <191> = local7.debug See RFC 3164 Section 4.1.1 - "PRI Part" or https://devcentral.f5.com/wiki/iRules.HSL__send.ashx for more info set static::facility <191> Add the facility and hostname to the log prefix set static::hsl_prefix "$static::facility|host=$static::bigip" } when CLIENT_ACCEPTED { Open a new high speed logging connection to the syslog pool named syslog_server_pool set hsl [HSL::open -proto UDP -pool syslog_server_pool] Append the client IP:port to a local copy of the log prefix so we can log it in SERVER_CLOSED set hsl_prefix "${static::hsl_prefix}|client=[IP::client_addr]:[TCP::client_port]" } when HTTP_REQUEST { Get time for start of HTTP request set http_request_time [clock clicks -milliseconds] set url "[HTTP::host][HTTP::uri]" } when HTTP_RESPONSE { Received the response headers from the server. Log the pool name, IP and port, status and time delta between HTTP request headers received from client and respnse headers recieved from server HSL::send $hsl "$hsl_prefix|event=HTTP_RESPONSE|url=$url|vs=[clientside {IP::local_addr}]:[clientside {TCP::local_port}]\ |http_status=[HTTP::status]|http_request_response_delta_ms=\ [expr {[clock clicks -milliseconds] - $http_request_time}]|desc=HTTP response|\n" }
Aaron - Ah_Fat_2262
Hi Aaron,
Thanks very much on the assistance. I will try it out. However, I have a couple of questions
1) Do I just use the quoting as provided or Do I still need to add/change/configure the value for some of the line?
2) For the line of set hsl [HSL::open -proto UDP -pool syslog_server_pool] what if I do not have such a remote server group?
However, I have added a remote server using the below command instead
bigpipe syslog remote server {server1 {host xx.xx.xx.xx}}
Please advice.
All you should need to do is define your syslog server in a pool named syslog_server_pool:
b pool syslog_server_pool {members xx.xx.xx.xx:514}
b save
If you want to send the logs to something other than local7.debug, change this variable to the value described on the HSL::send wiki page (https://devcentral.f5.com/wiki/iRules.HSL__send.ashx):
Aaron
