benoit_9199's avatar
benoit_9199
Nov 17, 2009
Logging FTP access data (with NETed FTP virtual serveur)
Due to some constraints i had to setup an FTP virtual serveur on an bigip,
using SNAT. However this has a limitation, the end server cannot see the real
source IP.
So, using ideas from the different Log* samples and the passive_ftps_in_ccc_mode iRule,
I'm trying to cook an access log iRule.
My problem is that whenever i add TCP::collect to the CLIENT_ACCEPTED event the ftp connection fail
(the client is connected but there is no response from the F5)
here is what i've got now, any idea ?
when CLIENT_ACCEPTED {
    set vip [IP::local_addr]:[TCP::local_port]
    set user "unknown"
    TCP::collect
 when SERVER_CONNECTED {
    set client "[IP::client_addr]:[TCP::client_port]"
    set node "[IP::server_addr]:[TCP::server_port]"
    set inside "[serverside {IP::local_addr}]:[serverside {TCP::local_port}]"
 when CLIENT_CLOSED {
     log connection info
    log local0. "FTP connection from $client. Mapped to $inside -> $node, user $user"
 when CLIENT_DATA {
    check if payload contains the string we want to replace
   if { [TCP::payload] contains "USER" }
       use a regular expression to save the user name
      regexp "USER \(\[a-zA-Z0-9]+)"  [TCP::payload] all user
      release the packet, and end collection
     TCP::release
   else
      release the packet, and collect a new one
     TCP::release
     TCP::collect
    Could it be that the session is put on hold due to the TCP::collect while the client is waiting from the server
    to answer so it can't speak ?
  • Yep, looks like it's more like this:
        set user "unknown"
        TCP::collect
        TCP::collect
     when SERVER_DATA {
      TCP::release
      clientside { TCP::collect }
     when CLIENT_DATA {
       log local0. "[IP::client_addr]:[TCP::client_port]: collected payload ([TCP::payload length]): [TCP::payload]"
           log connection info
          TCP::release
          return
       else {
          TCP::release
          TCP::collect
  • mendoza_60364's avatar
    mendoza_60364
    Historic F5 Account
    Hello Everyone,
    I've gone ahead and added this to the code share at the following link:
    http://devcentral.f5.com/wiki/defau...gging.html
    I've changed some changes to the packet collection and instead of having it return, I've had it continue collecting to capture a larger spread. It also gave me the ability to watch multiple login/logout FTP commands for tracking. Without this change only the initial login is caught and the user would be able to logout and back in with another username.
