Log options for connection limits
Continuing with connection limits, is there any way to log when the limit is reached for a particular member? Or to send an SNMP trap? The only thing I've seen during my testing is that an entry in /var/log/ltm is written when ALL the members have reached theirs limits, as the pool itself becomes unavailable.
Thanks very much.
We had the same issue and submitted an RFE. The more people interested in a feature, the more likely it is to get traction. If this is something you'd like to see, it would probably be worth the time to open a case and get associated with the RFE.
Thanks.
- Walter_Kacynski
Did you get an RFE ID/Number? - here you go. 224988 - Thanks.
