dirken's avatar
dirken
Sep 07, 2021
log entry cut off - max size for variable or log entry?
I am logging the Java Web Token (JWT) during an Oauth login. The iRule works in general, but the JWT is cut off after 890 characters.
Cannot find any reason for it, as log entries and variables should be able to hold more than that. Here's my iRule:
   if { [HTTP::header exists Authorization] and [HTTP::header Authorization] contains "Bearer" } {
       set jwt [getfield [HTTP::header Authorization] " " 2]
       log local0. "JWT: Client [IP::client_addr] arrived with JWT: $jwt"
  • Hello Dirken.
    Take into account that log entries have a maximum size per message.
    "The syslog facility is limited to logging 1024 bytes per request. Longer strings will be truncated."
    REF - https://clouddocs.f5.com/api/irules/log.html
    Possible solutions:
    1. Use HSL (https://clouddocs.f5.com/api/irules/HSL.html)
    2. Capture traffic using tcpdump and decrypt it later on
    Regards,
    Dario.
