_____269222's avatar
_____269222
Sep 26, 2016
LocalLB::Pool::get_member_monitor_rule raises Exception when HealthMonitor is "Inherit from Pool"
get_member_monitor_rule raises Exception when Health Monitor of member is set "Inherit from Pool", as follows:
>>> bigip.LocalLB.Pool.get_member_monitor_rule(['TEST'], [[{'port': 443, 'address': '/Common/5.5.5.5'}]])
Traceback (most recent call last):
  File "", line 1, in
  File "/usr/lib/python2.6/site-packages/bigsuds.py", line 463, in wrapped_method
    result = method(*args, **kwargs)
  File "/usr/lib/python2.6/site-packages/suds_jurko-0.7.dev0-py2.6.egg/suds/client.py", line 566, in __call__
    return client.invoke(args, kwargs)
  File "/usr/lib/python2.6/site-packages/suds_jurko-0.7.dev0-py2.6.egg/suds/client.py", line 705, in invoke
    result = self.send(soapenv)
  File "/usr/lib/python2.6/site-packages/suds_jurko-0.7.dev0-py2.6.egg/suds/client.py", line 753, in send
    return self.process_reply(content, e.httpcode, tostr(e), headers)
  File "/usr/lib/python2.6/site-packages/suds_jurko-0.7.dev0-py2.6.egg/suds/client.py", line 820, in process_reply
    raise WebFault(fault, replyroot)
bigsuds.ServerError: Server raised fault: 'Exception caught in LocalLB::urn:iControl:LocalLB/Pool::get_member_monitor_rule()
Exception: Common::OperationFailed
        primary_error_code   : 16908342 (0x01020036)
        secondary_error_code : 0
        error_string         : 01020036:3: The requested monitor rule (1 /Common/http 3 0 ) was not found.'
