LocalLB::Pool::create - How to create a pool ala bigpipe
I'm trying to use the SOAP API to replace some bigpipe commands. Currently, we're automagically configuring the BIG-IP for environments at order time with our custom private cloud. Our automated process currently ssh's to the F5 and runs specific bigpipe commands depending on what configuration the customer orders ( pools, members, SSL, iRule versions, etc. ) For example, we loop through creating all the base elements based on a stored DB config for an "environment"
As such, we've got some singleton commands ( in this case, an empty pool. )
e.g.
bigpipe pool $BigIpCreatePool.PoolName { monitor all tcp }
Multiple calls to this based on how many pools this env should have ( e.g. select bigIPPoolName from bigIPEnvConfig; might return 3 pools for env type A, and 7 for env type B.)
I'd like to do the same using a soap call to ( iControl )LocalLB::Pool::create.
I can, if I specify pool members at creation time:
--- well, it seems you can't embed XML here. Rats! ---
soap:Envelope soap:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/"
soap:Body
create xmlns="urn:iControl:LocalLB/Pool"
pool_names soapenc:arrayType="xsd:string[1]" xsi:type="soapenc:Array"
item xsi:type="xsd:string"scooby_doo/item
/pool_names
lb_methods soapenc:arrayType="xsd:string[1]" xsi:type="soapenc:Array"
item xsi:type="xsd:string"LB_METHOD_ROUND_ROBIN/item
/lb_methods
members soapenc:arrayType="soapenc:Array[1]" xsi:type="soapenc:Array"
item soapenc:arrayType="xsd:anyType[1]" xsi:type="soapenc:Array"
item
address xsi:type="xsd:string"11.48.7.236/address
port xsi:type="xsd:int"8080/port
/item
/item
/members
/create
/soap:Body
/soap:Envelope
I can't see a way to create just an empty pool - we'll be looping through adding the members later, some of the process is asynchronous - I may or may not know the complete list of nodes up front, due to the existing automated process ( and some external integration points. )
- George_Watkins_Historic F5 Account
Hi Brooke,
I can't tell which SOAP library you're using so I'll give a couple different examples. There is an example written in Perl in the CodeShare: Perl Create Pool. If you're into Ruby, you can download the Ruby Library, install it (or just 'gem unpack' to extract the contents), and locate a sample script called 'create-http-virtual-and-pool.rb' in the 'examples' folder. That script is full of sanity checking goodies that will make your life easier.
-George
- Brooke_Gravitt_
HI! Thanks for the reply. It isn't that I can't create a pool ( the SOAP XML in my post works just fine. )BTW, I am not using *ANY* of the libraries, we'll be communicating directly with iControl from an ESB via SOAP.
The question is how can I create just an *empty* pool. The iControl SOAP API is expecting
-Pool Name
-Load Balancing Type
-Member List ( [ Member IP, Port ] )
I'd like to create the pools, empty, as we do now ( via bigpipe,) and add the members later. If it's not possible, I'll have to add a dummy pool member and remove it later.
- To create a pool with no members, you'll just need to pass in the following parameters
string [] pool_names - array size 1 with the value of the pool name
LBMethod [] lb_methods - array size 1 with value of lb method
IPPortDefinition[][] members - 2-d array with 1st degree of size 1 (for the supplied pool) an the second degree with size 0 (for no members).
This can be done with the following perl code:@MemberDefA; push @memberDefAofA, [@memberDefA]; $soapResponse = $Pool->create( SOAP::Data->name(pool_names => [$sPool]), SOAP::Data->name(lb_methods => ["LB_METHOD_ROUND_ROBIN"]), SOAP::Data->name(members => [@memberDefAofA]) ); &checkResponse($soapResponse);
This will result in the following SOAP message (with angle brackets replaced by brackets)[soap:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" soap:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/"] [soap:Body] [create xmlns="urn:iControl:LocalLB/Pool"] [pool_names soapenc:arrayType="xsd:string[1]" xsi:type="soapenc:Array"] [item xsi:type="xsd:string"]foopool[/item] [/pool_names] [lb_methods soapenc:arrayType="xsd:string[1]" xsi:type="soapenc:Array"] [item xsi:type="xsd:string"]LB_METHOD_ROUND_ROBIN[/item] [/lb_methods] [members soapenc:arrayType="soapenc:Array[1]" xsi:type="soapenc:Array"] [item soapenc:arrayType="xsd:anyType[0]" xsi:type="soapenc:Array" /] [/members] [/create] [/soap:Body] [/soap:Envelope]
Hope this helps...
-Joe
