jross_47179
Dec 15, 2010LocalLB::Class::set_string_class_member_data_value does not work
The LocalLB::Class::set_string_class_member_data_value API does not appear to save values as expected.
First, a call to add_string_class_member() on an existing data group is immediately followed by a call to set_string_class_member_data_value() on the newly added member; the member itself is saved (i.e., the first call) yet the value (i.e., the second call) is not saved.
The API is being invoked using python via the PyControl_v2 Library.
There are no apparent errors in the LB log file, /var/log/ltm and even when enabling debugging, the output shows good SOAP responses. Below is an example script and the output that demonstrates the above-described behavior - I'm wondering if I'm missing a step or doing something wrong.
Any thoughts, recommendations, etc. would be most welcome. Thanks in advance!
import pycontrol.pycontrol as pc
connect to LB
lb = pc.BIGIP(hostname = "x.x.x.x", username = "user", password = "password", fromurl = True, wsdls = ['System.SystemInfo', 'LocalLB.Class'])
si = lb.System.SystemInfo
print "Connected to F5 %s, version %s\n" % (si.get_marketing_name(), si.get_version())
c = lb.LocalLB.Class
create the class
c.create_string_class(classes = [{'name': "theClass", 'members': []}])
print "Contents BEFORE (should be empty):"
print c.get_string_class(["theClass"])
print c.get_string_class_member_data_value(c.get_string_class(["theClass"]))
print "\n"
add some members with values
c.add_string_class_member(class_members = [{'name': "theClass", 'members': ["theFirstMember"]}])
c.set_string_class_member_data_value(class_members = [{'name': "theClass", 'members': ["theFirstMember"]}] , values = [["theFirstValue"]])
c.add_string_class_member(class_members = [{'name': "theClass", 'members': ["theSecondMember"]}])
c.set_string_class_member_data_value(class_members = [{'name': "theClass", 'members': ["theSecondMember"]}] , values = [["theSecondValue"]])
print "Contents AFTER (should have two members with two values):"
print "\n"
cleanup to allow rerun
c.delete_class(classes = ["theClass"]) print "done.\n"
- Brett_Dargan_87
is this working for anyone, I have the same problem? - Nigel_Benns_660
This is working for me in Ruby on Version 11 api:
!/usr/bin/env ruby require 'rubygems' require 'f5-icontrol' require 'json' require 'socket' bigip = F5::IControl.new( 'host', 'user', 'pass', [ 'Management.Partition', 'LocalLB.Class' ] ).get_interfaces env = ARGV.shift nodes = ARGV begin bigip["LocalLB.Class"].create_string_class([ { "name" => "test-auto", "members" => [ "test1", "test2" ] } ]) bigip["LocalLB.Class"].set_string_class_member_data_value( [ { 'name' => "test-auto", 'members' => [ "test1", "test2" ] } ], [ [ "hi", "meow" ] ] )
