vokhoa_96970's avatar
vokhoa_96970
Oct 10, 2011
Loadbalance connection problem (Urgent!)
Hi all,
I'm facing with urgent problem when the initial connection from internal client to outside load-balance via three ISPs cause of dropped. The server refuse any connection from 2-3 addresses. So I must keep only one default gateway pool by disable others.
I'm not familiar with iRule, but I think it can result this issue. My idea is:
When Connnection Request= (domaina:3000 or http://mail.domaina.com)
{For each client_add
-> use only a gateway in default_gateway_pool
Any idea for this case or represent to iRule for me. Note that my device is LinkController so Layer_7 feature hasn't licensed.
Thanks so much,
Khoa
  • u want to use specific default gateway when requesting to specific destination, don't u?
    if so, can u try this? 1.1.1.1 is the destination and 2.2.2.2 is the gateway.
    when CLIENT_ACCEPTED {
       if {[IP::addr [IP::local_addr] equals 1.1.1.1]} {
          node 2.2.2.2
    IP::addr wiki
    http://devcentral.f5.com/wiki/iRules.IP__addr.ashx
    iRules IP Comparison Considerations with IP::addr Command by Jason
    http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/1086449/iRules-IP-Comparison-Considerations-with-IPaddr-Command.aspx
  • Thanks Nitass,
    But with your rule, I think it's not a feature of load-balancer.And also lost all connection to dest 1.1.1.1 when note 2.2.2.2 down.
    My ideas for this situation are:
    - For each IP client to server 1.1.1.1 with port 3000, LC will forward to a gateway:
    (Ex: PC1 -> Server:3000 -> ISP1 ; PC2 -> Server:3000 -> ISP2; PC3 -> Server:3000 -> ISP1)
    - Any configuration forward to gateway pool sticky/ persistence
    Thanks,
    Khoa
  • thanks, it appears i misunderstood your question. :-)
    - Any configuration forward to gateway pool sticky/ persistence have you ever tried source address persistence?
  • I've tried with source address persistence but it still load to all gateway pool member.
    Could u help me with the first solution by iRule?
    Thanks,
    Khoa
  • i don't think you need an irule. persistence should be able to do what you want.
    can you post virtual server configuration here?
  • This is my configuration about this VS, pls check it for me
    pool mail_pool {
    monitor all gateway_icmp
    members 210.211.108.119:any {}
    virtual vs_mail {
    pool mail_pool
    destination 210.211.108.119:hbci
    ip protocol tcp
    persist source_addr
    profiles {
    http {}
    tcp {}
  • This case have been solved by source address persistence configuration.
    Thanks Nitass for supporting.
