jaikumar_f5_226's avatar
jaikumar_f5_226
Jul 13, 2016
Solved
load-balancing-mode ratio-member syntax in 11.x CLI ?
Hey Folks,
Im unable to get the right syntax for ratio-member load balancing, any help would be highly appreciated. In GUI, its pretty straight. But in CLI, im having a hard time to get in place....
Requirement : 2 Pool members with ratio 50 for 1 member and 75 for other.
Where as in CLI, i tried the same in create pool command, no luck. Dont see the ratio option... So i first created the pool, then tried putting load balancing, still no luck.
If ratio option would be visible only after i choose the members, then again i have issues.
Im able to see the ratio value option only if i choose all, but again unable to define particular values of each members. Its taking a single ratio value for everything.
Can some one tell what im mistaking...
  • Hi,
    You can create a pool with associated pool members and ratio-member lb method using the following command example :
    create ltm pool deadpool load-balancing-mode ratio-member members add { 1.2.3.4:80 { ratio 80 } }
  • Hi,
    • jaikumar_f5's avatar
      jaikumar_f5
      Icon for Noctilucent rankNoctilucent
      Damn,,,, I dint explore this :) Thanks Yann, always loved your prompt responses.
  • Hi,
      jaikumar_f5
