tarma_58716
17 years agoLoad balancing gateways
hi guys
I would like to know, is it possible to load balance gateways.
i have two gateways and i would like to manage my virtual servers to choice one or the another gateway for traffic.
thanks you for your response.
- The_Bhattman
If you go to ask.f5.com they should have a Configuration and Solutions guide which show you how to balance between 2 gateways - provided that the 2 gateways are for simply outbound connections such as delivering internet traffic.
CB - Hamish
Cirrocumulus
Inbound traffic?
What you're looking for is a firewall sandwich. Works fine, but you need an F5 (or HAPair) on EACH side of the firewalls. Works fine, but you need to think carefully about how you configure the monitoring to mark the gateways up/down (And there's a few boundary conditions to do with failures of the gateways, but they're pretty minor and as rare as your gateways actually falling over). - The_Bhattman
Yes...the configuration guides in ask.f5.com should have a good example to start off with.
Bhattman
