Mohamedabogamil's avatar
Mohamedabogamil
2 years ago
Load balance_RDP
Hello team,
I create rdp  VS:192.168.3.143:3389 and access it through APM-VPN.
 I added 4 servers to the pool
(10.5.13.122 / 10.5.13.123 /10.5.13.124 / 10.5.13.125)   I used the Least session(member) and I tried using round robbin but the same behavior
if the first user  is connected  to 10.5.13.122 all users will come to this server and the session will be terminated
I used the default Persistence Type: Microsoft® Remote Desktop.
Fallback Persistence Profile used : source address
I expect this to happen because of the persistence profile I removed it, and I received the below issues:
The Connection Has Been Terminated Because An Unexpected Server Authentication Certificate Was Received From The Remote Computer
I used cli ti see the connection to check the user name  and I found all users come with  different names:
tmsh show /ltm persistence persist-records mode msrdp
msrdp kamc-jd\a 192.168.3.143:3389 10.5.13.122:3389 (tmm: 3)
msrdp KAMC-JD\z 192.168.3.143:3389 10.5.13.122:3389 (tmm: 2)
msrdp KAMC-JD\A 192.168.3.143:3389 10.5.13.122:3389 (tmm: 2)
msrdp kamc-rd\M 192.168.3.143:3389 10.5.13.122:3389 (tmm: 0)
