tatmotiv's avatar
tatmotiv
Jan 13, 2016
load balance ICMP echo requests to pool members
Hi there,
I'm trying to setup a virtual server which will forward ICMP to pool members and let them handle answering ICMP instead of letting the BigIP handle ICMP itself. My plan was to:
  1. disable ICMP echo in the virtual address setting:
    ltm virtual-address 10.2.1.23 {
       address 10.2.1.23
       icmp-echo disabled
       mask 255.255.255.255
       traffic-group traffic-group-1
  2. Define an appropriate pool with port "any":
    ltm pool test {
    members {
        docker_host1:any {
            address 10.100.1.10
  3. Define a fast-l4 virtual with ip-protocol icmp and destination port any and attach the pool to it:
    ltm virtual trestdjo {
    destination 10.2.1.23:any
    ip-protocol icmp
    pool test
    profiles {
        fastL4 { }
    source 0.0.0.0/0
    vlans {
        client
        server
    vlans-enabled
However, this virtual does not catch the pings coming in from vlan "client" to destination address 10.2.1.23. I can see the pings arriving in vlan client when running tcpdump, but they are left unanswered. The hit counts of the virtual above are not incrementing, so it doesn't seem to match the traffic. I'm unsure whether fastL4 is even capable of handling ICMP traffic, but it is the only type of virtual that allows me to specifiy ICMP as IP protocol (type standard doesn't) and attach a server pool to it.
Any idea how to achieve the desired behaviour? Many thanks in advance.
Regards
Martin
  • Additional information: The help text for ICMP echo in the virtual address section states: ICMP Echo Enables or disables responses to Internet Control Message Protocol (ICMP) echo requests on a per-virtual address basis. When enabled, the BIG-IP system intercepts ICMP echo request packets and responds to them directly. When disabled, the BIG-IP system passes ICMP echo requests through to the backend servers. The last sentence describes the desired behaviour, so I guess there has to be a way to achieve this...
  • Hi Tatmotiv,
    this feature looks somewhat broken to me...
    1. ICMP=enable and ARP=enable will cause LTM to respond
    2. Switching to ICMP=disable and ARP=enable will cause ICMP messages to become dropped.
    3. Switching to ICMP=disable and ARP=disable will cause the servers respond to ICMP messages, until the ARP caches are timed out (with static MAC entries it would continue to work)
    4. Switching to ICMP=disable and ARP=enable will cause half of the ICMP messages to become dropped and the other half is still responded by the servers.
    5. Switching to ICMP=enable and ARP=enable will cause LTM to respond half of the ICMP messages and the other half is responded by the servers.
    6. Clearing the Connection-Table while having ICMP=enable and ARP=enable will immediatly cause LTM to respond to everything.
    7. Going back to the state of 4.) and then clearing the Connection-Table will cause the ICMP messages to become dropped.
    8. Going back to the state of 3.) and then clearing the Connection-Table will cause the servers respond to ICMP messages.
    I'd recommend to call F5 support and ask for a fix/assitence...
    FYI: I'm using TMOS v12
    Cheers, Kai
