bigiptechie_982
Apr 16, 2012load balance between servers based on the Geographical location
- nathe
Cirrocumulus
bigiptechie,
I think an iRule will work for you here. I remembered there was a "20 lines or less" entry which had source Country information using "whereis" . So I've found the wiki for you to see if this can get you started:
https://devcentral.f5.com/wiki/iRules.whereis.ashx
Good look,
N - bigiptechie_982
Thanks Nathan
I found this dev link and it helped me a lot.
https://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/1082330/New-Geolocation-Capabilities-in-v101.aspx
