Roberto_GB_2613
Altostratus
9 years agolist data-group using tmsh script
Hi all, I'm developing some scripts in order to make easier certain operation with data-groups. I figured out how to add, modify and delete elements this way but when it comes to show the data-group... No way. I duplicated the same command but with different syntax to see if something worked:
cli script VPN_users_SHOW {
proc script::run {} {
set cmd "tmsh::list /ltm data-group internal auth_users_access"
tmsh::log "Executing the command: $cmd"
eval $cmd
list ltm data-group internal auth_users_access
To run the script I simply execute it: "run cli script VPN_tmp_user_access_SHOW"
I expected to list the data-group but it does not show any data. Any suggestion of what is missing?
