Python script for updating data group
Problem this snippet solves:
Updating data group via Python. From the article: Routing HTTP by request headers
Currently when you need to update a data group via iControl REST it requires you to retrieve a copy of all of the records, make your changes, and then re-submit all the records to make any changes. The following Python script takes care of the process of extracting all of the records, turning them into a dictionary, and then allowing the data group to be updated by passing a dictionary.
How to use this snippet:
This code can be imported as a class or run from the command-line. From the command-line:
% ./cgp.py add www.mycompany.example 10.10.1.11:80 added: www.mycompany.example % ./cgp.py get www.mycompany.example www.mycompany.example: 10.10.1.11:80 % ./cgp.py update www.mycompany.example 10.10.1.11:8000 updated: www.mycompany.example % ./cgp.py del www.mycompany.example deleted: www.mycompany.example
From code
from cgp import CGP BIGIP_ADDRESS = '[BIGIP MGMT HOST]' BIGIP_USER = '[admin user]' BIGIP_PASS = '[admin password]' DATA_GROUP = '~Common~[data-group name]' cgp = CGP(BIGIP_ADDRESS, BIGIP_USER, BIGIP_PASS) # get record data = cgp.get_data_group(DATA_GROUP) # add record data['www.mycompany.example'] = '10.10.1.10:80' cgp.set_data_group(DATA_GROUP, data) # update record data = cgp.get_data_group(DATA_GROUP) data['www.mycompany.example'] = '10.10.1.10:80' cgp.set_data_group(DATA_GROUP, data) # delete record data = cgp.get_data_group(DATA_GROUP) del data['www.mycompany.example'] cgp.set_data_group(DATA_GROUP, data)
Code :
#!/usr/bin/python
# Chen Gateway Protocol
# Example of using iControl REST
# From: https://devcentral.f5.com/s/articles/routing-http-by-request-headers
# Requires iControl REST > 11.5.0
# The following script allows one to dynamically update a data-group via
# iControl REST
import requests
import json
class CGP(object):
def __init__(self, host, user, passwd):
self.host = host
self.user = user
self.passwd = passwd
self.mgmt_url = "https://%s/mgmt/tm" %(host)
self.session = requests.session()
self.session.auth = (user, passwd)
self.session.verify = False
self.session.headers.update({'Content-Type':'application/json'})
def get_data_group(self, datagroup):
req_url = "%s/ltm/data-group/internal/%s" %(self.mgmt_url, datagroup)
req = self.session.get(req_url)
return dict([(a['name'],a['data']) for a in req.json()['records']])
"return contents of data-group as dictionary"
def set_data_group(self, datagroup, data):
records = {'records': [{'data':r[1],'name':r[0]} for r in data.items()]}
req = self.session.put(req_url,data = json.dumps(records) )
"update contents of data-group as dictionary"
if __name__ == "__main__":
import argparse
import sys
parser = argparse.ArgumentParser()
parser.add_argument('action')
parser.add_argument('host_header')
parser.add_argument('node_ip_port',nargs='?')
args = parser.parse_args()
if args.action == 'del':
if args.host_header in data:
del data[args.host_header]
print "deleted:", args.host_header
else:
print "error: %s does not exist" %(args.host_header)
sys.exit(1)
elif args.action == 'add':
print "error: %s already exists" %(args.host_header)
sys.exit(1)
else:
data[args.host_header] = args.node_ip_port
print "added: %s" %(args.host_header)
elif args.action == 'update':
print "updated:", args.host_header
else:
sys.exit(1)
elif args.action == 'get':
print "%s: %s" %(args.host_header,data.get(args.host_header,"DOES NOT EXIST"))
cgp.set_data_group(DATA_GROUP, data)Tested this on version:
11.5Updated Jun 05, 2023
Version 2.0Eric_Chen
Employee
Joined May 16, 2013
5 Comments
- Robert_47833
Altostratus
it doesn't work teach me hehe - Robert_47833
Altostratus
it needs to replace all values in the datagroup when add/delete/update? any other better way? - Eric_Chen
Employee
Robert, I'm not aware of a method to perform an incremental update of a datagroup at this time. There was a similar question on DevCentral: https://devcentral.f5.com/s/feed/0D51T00006i7Y1FSAU - Robert_47833
Altostratus
thanks,Eric I have completed my python version yeah, there is no way to perform an incremental update of a datagroup - Frank_Ren_37733
why i got a problem which said "keyerror:'records'"?how can i resolve the question? tks
