lstewart_53611
Apr 21, 2010Limiting number of connected clients
I am trying to write a rule to limit the number of individual clients that can connect to a VS, but not limit the total number of connections that they can have. After that limit has been reached, additional attempted connections should be dropped. So say 1000 clients (individual IPs) connect, any requests from additional clients are rejected, while any requests from already-connected clients are fine.
I think I might need to get some persistence in on the action, but I'm not sure if that's the best way to go about it. I think what I have hear will actually limit the number of total connections rather than the number of clients:
when RULE_INIT {
set ::connectedclients { }
when CLIENT_ACCEPTED {
set client_ip [IP::remote_addr]
if { [info exists ::connectedclients] } {
if {$::connectedclients > 1000 } {
reject
return
incr ::connectedclients
set ::connected 1
when CLIENT_CLOSED {
incr ::connectedclients -1
if { $::connectedclients <= 0 } {
unset ::connectedclients
The client_ip variable is unused above, though it needs to be used. I don't want to try to keep a list of 1000 IPs to check through, obviously. Any ideas? I thought of setting IP persistence and limiting the total to 1000 in that fashion, but there's no real way for me to decrement the connected users in tat way. However, I can abandon that portion and only allow 1000 clients to connect in a certain time period.
- Ian_SmithRet. Employeecheck this code share rule:
http://devcentral.f5.com/wiki/default.aspx/iRules/HTTPRequestThrottle.html - lstewart_53611
Ian - the linked rule is still trying to limit the number of connections per client. What I'm trying to do is limit the number of clients without limiting the connections per client. I'm not coming up with an elegant (or just quick) way to store a list of a fairly large (I'm using 1000 in my example) number of client_ip entries to check against to see if connections from that client are allowed and to not allow further clients once the quota is full. - hoolio
I think tracking 1000 client IPs is necessary if you want to allow the first 1000 clients to open as many connections as they try to. Here is an iRule which should support your scenario. It tracks the client IP and count of concurrent TCP connections. This way the client can open multiple connections. The client IP is removed from the array when their last connection is closed.
I didn't test it so let me know if you run into any issues when you test it.
Aaronwhen RULE_INIT { Initialize a new array of client IP addresses set ::clients { } } when CLIENT_ACCEPTED { Check if the client IP is already in the array if {[info exists ::clients([IP::client_addr])]}{ Client already exists in the array, so increment the connection count incr ::clients([IP::client_addr]) } else { Client IP isn't in the array, so check if we're under the limit if {[array size ::clients] < 1000}{ Allowing this client, so add them the array with one connection counted set ::clients([IP::client_addr]) 1 } else { We're over the limit, so reject the connection reject } } } when CLIENT_CLOSED { Check if the client IP is in the array (this should always be true) if {[info exists ::clients([IP::client_addr])]}{ Decrement the count incr ::clients([IP::client_addr]) -1 If the count is less than 1, remove the client IP from the array if {$::clients([IP::client_addr]) < 1}{ unset ::clients([IP::client_addr]) } } } - Claes_16575
Oh, this is exaclty what I'm looking for, but the above code is not working for me.
I'm running 10.2.1 473, and get this error in the LTM logfile:
- can't set "::clientcount(10.0.14.241)": variable isn't array while executing "set ::clientcount([IP::client_addr]) 1"
This iRule is meant to "slow start" our site after we had mainenance, to only let a few people warm up the caches and stuff on the app servers.
So, what I'm really looking for is a way to limit the number of unique visitors, and increase this value if needed. They should have full access to the site if they arrive and get's an "open slot" in the array, and if the array if full, we will present the maintenace page instead.
Any suggestions on an already developed and working iRule for this scenario?
Regards // C - nitass
Employee
there is an example irule to limit a vip to a number of connections in the following article. the best thing is that it is cmp compatible. is it applicable for your situation?
v10.1 - The table Command - Counting by Spark
http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/2381/v101--The-table-Command--Counting.aspx
hope this helps. - Claes_16575
Thanks.
I don't really want to limit the number of connection, rather than the numer of unique visitors. (IP's)
We run a very popular site, where ppl login and brows 'round. If i limit the number of connection, an already logged in user might lose a connection during something, and a user not logged in might get a connection.
Was really hoping the above piece of code would work, since it's exactly what i want to accomplish =) - nitass
Employee
i revised the table command's example a little bit. may it be usable?[root@ve1023:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.65.152:ssh ip protocol tcp rules myrule } [root@ve1023:Active] config b rule myrule list rule myrule { when CLIENT_ACCEPTED { event CLIENT_CLOSED disable set tbl "clientlimit" set key "[IP::client_addr]" log local0. "[IP::client_addr]:[TCP::client_port]|[table keys -subtable $tbl]|[table keys -subtable $tbl -count]" if {[table lookup -subtable $tbl $key] equals ""} { if {[table keys -subtable $tbl -count] > 0} { reject log local0. "[IP::client_addr]:[TCP::client_port] is rejected" } else { table set -subtable $tbl $key "ignored" 180 set timer [after 60000 -periodic {table lookup -subtable $tbl $key}] event CLIENT_CLOSED enable } } } when CLIENT_CLOSED { after cancel $timer table delete -subtable $tbl $key } } [root@ve1023:Active] config tail -f /var/log/ltm Nov 15 08:27:58 local/tmm info tmm[4766]: Rule myrule : 192.168.204.7:53985||0 Nov 15 08:28:05 local/tmm info tmm[4766]: Rule myrule : 192.168.204.7:53989|192.168.204.7|1 Nov 15 08:28:15 local/tmm info tmm[4766]: Rule myrule : 192.168.204.7:53991|192.168.204.7|1 Nov 15 08:28:24 local/tmm info tmm[4766]: Rule myrule : 172.28.17.30:56279|192.168.204.7|1 Nov 15 08:28:24 local/tmm info tmm[4766]: Rule myrule : 172.28.17.30:56279 is rejected
