SynACk_128568's avatar
SynACk_128568
Feb 27, 2015
least-connections-member and least-connections-node
Hi All,
i was trying to find when to use node and when to use member least connection . i thought the least connection is based on connection for particular VS it will not be affected by other VS coonection count ?
When to use member and node any specific scenarios for example if same node is referenced in different pools ?
  • Least connections member can be viewed as sorting a list of pool members in a pool by the number of open connections (tcp/udp/etc.).
    Least connections node can be viewed as sorting the list of pool members by total connections to the node object, referencing the entire connection table of the BIG-IP.
    I would look at using least connections member mostly, but if you have a machine that takes the same type of data on multiple ports, say a server that hosts web sites different ports (say tcp/8000-8019), and each port is associated with a virtual server with pools referencing only 1 port, then least connections node on all of those pools may make sense.
  • How will it play, if we have Priority group activation in picture for a pool. Will in that case the connection move to the nodes in group with lower priority?
  • In our network scenario priority group activation works for active passive node scenario.
    lets suppose there are 2 nodes in a virtual server and user wants to get the traffic on node 1. If in case node 1 goes down then traffic automatically moves to node 2.
    In above scenario we follow below configuration steps :-
    +create pool active_passive +select round robin method +select priority group activation as we want to make only one node active at a time +select node and set priority to the node
    The higher the number, the higher the priority, so a member with a priority of 3 has higher priority than a member with a priority of 1.
    +lets suppos node 1 has priority 2 ---so it will recieve traffic first. Once it goes down then only traffic move to the node 2 with lower priority.
  • Comment made 29-Nov-2016 by er.sandy 56 How will it play, if we have Priority group activation in picture for a pool. Will in that case the connection move to the nodes in group with lower priority?
