Meena_Agnihotri's avatar
Meena_Agnihotri
Dec 07, 2015
Connection tracking for LB-algorithm of Least-connections(member)
Hello.
I have 3 DNS servers that I'm load-balancing with a pair of LTMs. I'd like to use the LB-method of Least-connections(member). I'd also like to set the idle-timeout to "immediate" for all DNS (UDP/53) traffic as there is no reason to keep connection information. The topology is nPath-direct server return.
My questions is:
  1. Where is the LTM tracking which server it sent the connections to - specifically for the purpose of the LB-algorithm?
  2. Is it "show sys connections" or some other table?
  3. By setting the timeout to "immediate", the entries in the "show sys connections" table would be gone so that can't work with the LTM's LB algorithm.
I'm thinking its a different table but I can't find definitive information on it.
Thanks for the help.
  • Where is the LTM tracking which server it sent the connections to - specifically for the purpose of the LB-algorithm?
    F5 is actually tracking the connections that have not been terminated yet (either active or idle) between the F5 itself and the pool members. You can play with "show sys connections" to view those connections but I would rather use GUI statistics or "show ltm pool MY_POOL detail" to get the current open connections for each members.
    Yes, Least connections (member) would not be a good choice in that case as you are almost immediately removing the new entries from the connection table. For information, I said almost immediately because there is a scheduler that runs every X seconds (I can't recall the X) which clears every connection that is elligible for deletion.
    F5 cannot track current connections between your servers and other systems in the network. I wonder if It is possible using a SNMP or WMI monitor.
