Ilian_Ivanov's avatar
Ilian_Ivanov
8 years ago
LCD warnings and the Alarm LED
Is there a way to see what is displayed on the LCD and what are the status of the LED remotely? (in CLI or GUI)
  • Hello Illian,
    Based on this F5 KB, It is not possible to do that:
    https://support.f5.com/csp/article/K11094
    "Note: You cannot view LCD warnings and Alarm LED messages remotely. To ensure that the alerts do not reappear, F5 recommends that you monitor the BIG-IP log files after you clear the LCD warnings or Alarm LED."
    But some times, I had the case where some log severity events "Emergency" "Alert" and "Critical" are shown on LCD screen and also in the /var/log/ltm or other file under /var/log/ (like /var/log/kern).
    Maybe you can use the command "grep emerg /var/log/*" to view these events...
    Regards
