Layer 7 monitoring
if we want to configure layer 7 monitor how to we choose
send/receive string and is it possible to check only particular string
on server and marked the pool memeber has down or do we need to configure whole string with <html > body or just a 2 words?
- iaine
Nacreous
Hi
The monitor uses string matching so you can use either the whole line or just part of it depending on how detailed you need to make your monitor. So you can use just 2 words if that is a good way to check service availability
- Lidev
Nacreous
Hi Gaji,
check this KB, you have several options to do health monitors with send/receive string : https://support.f5.com/csp/article/K5917
