Duncan_Proffitt's avatar
Duncan_Proffitt
Apr 25, 2018
LAB installation.
Got all the bits up and running, but when I try and access the LAMP server on 10.1.10.20 as per the instructions, I dont get the images, as I would expect, I get ...
It works!
This is the default web page for this server.
The web server software is running but no content has been added, yet.
What have I missed?
  • This is not an issue on the LTM or flow. You have installed LAMP server and if you open the index.html file, you would see the same content in there too.
    Also may I know which LAB instructions you are following please ?
  • Assuming you are using the Partner Vlab setup and the LAMP_v6 server with all the default settings, I believe you have configured the pool with a pool member on 10.1.20.252 rather than using 10.1.20.11 to 10.1.20.15.
    If you look at the last page in the exercise guide it should contain in appendix B a full list of all backend IP addresses.
