kgaigl's avatar
kgaigl
May 10, 2022
Solved
K14823198: ASM guided configuration not synced to peer device after upgrade impact
Hello,
after Upgrade an active/standby cluster to 16.1.2.2 I ran into this:
https://support.f5.com/csp/article/K14823198
now I've 2 questions:
1. do I have to run this commands on active or standby?
2. what impact have this commands? I'm afraid of both units are active for a minute or so.
Thank you
  • Solution:
    F5-Support provided me a Script "ha-sync" and after run
    /var/tmp/ha-sync --force -H 192.168.97.2 -D device-group-failover-21b78xxxx
    everything's ok now
  • kgaigl's avatar
    kgaigl
    thank you, but my concern is, that if the device-trust is reset, then for a (very short) time both units are active and so there would be IP Adress Conflict when the same VIP's on both units are active.
    I think about the commands  restcurl -X DELETE...
    I will try after Office Hours
    • If you are worrying about split brain you can make the standby in offline mode this way it will not take over as active even when the trust is broken between the HA pair.
    • Hello,
      After the upgrade please share if everything is ok and if you saw any issues so we can close the question.
      • kgaigl's avatar
        kgaigl
        I'm in contact with the support, they told me to change in Ressource Provisioning the Management from Small to Large, now:
        [root@ldb-ara31-brz-00:Standby:In Sync] ~ # restcurl shared/gossip |egrep '\"status\"|\"gossipPeerGroup\"'
          "status": "ACTIVE",
          "gossipPeerGroup": "tm-shared-all-big-ips",
        in the overview of the Security Policies the Policies are present and attached to the VS, but under Guided Configuration, the Policies are still not present.
        It looks like a displaying Error.
        tried to export/import the Policies, get an Error, Policy already exists
        tried to create a new Policy, this will also not displayed on the standby
  • kgaigl's avatar
    kgaigl
    after running the described actions, it's still the same on the standby-unit:
      "status": "UNPAIRED",
  • kgaigl's avatar
    kgaigl
    Solution:
    everything's ok now
