Java RDP - Connection Exception
Has anyone started to get this error when use Java RDP from a Mac?
I had this error in the past then it just started working once I updated Java. I am currently running Java 8 Update 45. I have added my site that I connect to to the security exceptions page.
I have tried different combinations with Port Translation and Address Translation, but that just broke it completely. I have tried different screen size combinations because we have seen that issue in the past.
My host file is setup correctly as well and can ping my own machine.
I have Java enable on the Virtual Server as well as on the RDP settings for that resource.
- Amit_Karnik
Do you assign a non-default route-domain in the policy ?
We ran into that issue in 11.5.1. For Java based connections the policy assigned route-domain was not being selected and the connection would initiate from the default route-domain.
This is fixed in 11.6.0
