Issue with VIP
Hi Team,
I am having a very simple requirement where:
- Frontend URL is: https://wsgwtest.test.no:2443/Test/ElsmartElwinWS/ while the Internet application URL is: http://bizref4.test.no/Net.InstallationRegister/
What will be the steps I need to focus on:
- Do, I need to consider Port 2443 also while configuration ? Because into the Frontend, I am creating HTTP and HTTPS VIP, HTTP-VIP is just for redirection from HTTP and HTTPS.
2.How I will do this rewrite as Frontend request URI is not similar to the backend application sever URI ?
- Thirdly I need to restrict the URL from only specific sources 3.3.3.3 and 3.3.3.4 in F5 LTM only plus only user: 'test' can only access https://wsgwtest.test.no:2443/Test/ElsmartElwinWS/, but no other users, kindly guide into the same.
Regards PZ
- Parveez_70209
please read as *Internal application URL is: http://bizref4.test.no/Net.InstallationRegister/ - Snl
you can do this by doing ssl offloading and applying couple of irules to the virtual server - Amy_123193Historic F5 Account
SSL must be terminated at the BIG-IP for this to work, and you should consider using a Rewrite profile to change the URI in-flight - it works similarly to the Apache ProxyPass feature.
- Parveez_70209
Sorry it was not very clear.. I mean: 1. For VIP: Do I need to create HTTPS:SSL VIP with port 2443 ? 2. Rewrite Profile part I understood. 3. Thirdly I need to restrict the URL from only specific sources 3.3.3.3 and 3.3.3.4 in F5 LTM only plus only user: 'test' can only access https://wsgwtest.test.no:2443/Test/ElsmartElwinWS/, but no other users, kindly guide into the same ?
- awilhelm
Employee
- Parveez_70209
