mkumar1113_2457's avatar
mkumar1113_2457
7 years ago
Solved
issue with URL after certificate renewal.
Can anybody please help me on the issue:
After renewing the certificate of F5 URL,we are getting the following error message and URL is not working after certificate renewal.
Note: Server SSL is not applied on VIP.
Error 404--Not Found From RFC 2068 Hypertext Transfer Protocol -- HTTP/1.1: 10.4.5 404 Not Found
The server has not found anything matching the Request-URI. No indication is given of whether the condition is temporary or permanent.
If the server does not wish to make this information available to the client, the status code 403 (Forbidden) can be used instead. The 410 (Gone) status code SHOULD be used if the server knows, through some internally configurable mechanism, that an old resource is permanently unavailable and has no forwarding address.
  • Hi mkumar1113,
    Please check if you are requesting the correct information from the server. Had you checked the same URI before renewing the certificate? And did that worked?
    404 error is because you are requesting some content which the server is not aware of.
    I would suggest checking with the team hosting the application to provide the correct URI or have them only verify the site.
  • Hi mkumar1113,
  • Can you please provide your virtual server and SSL client profile configuration. While providing configuration please mask your IP addresses etc..
