snovakov_86258's avatar
snovakov_86258
Feb 07, 2012
Issue with System.ConfigSync.download_configuration() method?
Hey iControl experts,
I'm using the iControl:System.ConfigSync.download_configuration() method and successfully pulling the following configuration files from an F5 Big IP appliance:
/config/low_profile_base.conf
/config/bigip_sys.conf
/config/bigip_base.conf
/config/profile_base.conf
/config/daemon.conf
/config/bigip.conf
/config/bigip_local.conf
However, when I try to pull the following 2 configuration files (which I've confirmed *do* exist on the appliance), I get an error return code of 16908289:
/defaults/config_base.conf
/usr/share/monitors/base_monitors.conf
The error looks like:
SOAP-ENV:Server :Exception caught in System::urn:iControl:System/ConfigSync::download_file() Exception: Common::OperationFailed primary_error_code : 16908289 (0x01020001) secondary_error_code : 0 error_string : Error opening file for read operations
I've looked this return code up, and it appears to be a file lock issue.
Could this be because the last 2 files are in a different partition or something?
I believe the /defaults/config_base.conf is a symbolic link.
I'm using v10.2.0 of iControl (Perl).
I'm calling the iControl:System.ConfigSync.download_configuration() method like:
my $soapResponse = $session->download_file(
SOAP::Data->name(file_name => $filename),
SOAP::Data->name(chunk_size => $chunk_size_val),
SOAP::Data->name(file_offset => 0) );
where $filename is the complete path to the 2 files mentioned above,
where $chunk_size_val = 131072, and
where I'm trying to read the whole thing in one fell swoop.
Could the 2 files mentioned be so large that it's failing due to me trying to do it in one chunk that isn't large enough?
I don't have command-line access to the appliance, or I would check the file sizes (in bytes) myself.
~ snovakov
