oscar_prieto_sa
Jul 08, 2011Issue with .ico
Hi, I execute scripts Invalidated_LWP for an object .ico, and see that
have an error of Cache Invaildated. For other object work correctly. Our
version of equipment is 9.4.8 and not if it supports the scripts for
the object or .ico Can anyone help?
Best Regards,
- Colin_Walker_12Historic F5 AccountI'm not sure I follow. What is it you're actually trying to accomplish, and what error messages are you getting in the logs?
Is this an iRule related problem? It sounds more like a configuration issue of some sort.
Colin - hoolio
I'm guessing this might be related to Web Accelerator. If so, you might try posting here:
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/37/aff/23/showtab/groupforums/Default.aspx
Aaron
