mkumar1113_2457's avatar
mkumar1113_2457
Feb 27, 2019
Issue with F5 URL.
Application servers log files we are seeing below kind of warning messages every 5 seconds.
[Tue Feb 26 17:53:38 UTC 2019] (Thread-2224) MWA_PH_INIT_CLIENT_FAIL: Fail to initialize client. Disconnecting it now. java.net.SocketException: Broken pipe (Write failed) at java.net.SocketOutputStream.socketWrite0(Native Method) at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:115) at java.net.SocketOutputStream.write(SocketOutputStream.java:140) at oracle.apps.mwa.presentation.telnet.Options.sendDo(Options.java:207) at oracle.apps.mwa.presentation.telnet.Options.startNegotiation(Options.java:160) at oracle.apps.mwa.presentation.telnet.ProtocolHandler.run(ProtocolHandler.java:540) [Tue Feb 26 17:53:43 UTC 2019] (Thread-2226) MWA_PH_INIT_CLIENT_FAIL: Fail to initialize client. Disconnecting it now. java.net.SocketException: Broken pipe (Write failed) at java.net.SocketOutputStream.socketWrite0(Native Method) at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:115) at java.net.SocketOutputStream.write(SocketOutputStream.java:140) at oracle.apps.mwa.presentation.telnet.Options.sendDo(Options.java:207) at oracle.apps.mwa.presentation.telnet.Options.startNegotiation(Options.java:160) at oracle.apps.mwa.presentation.telnet.ProtocolHandler.run(ProtocolHandler.java:540) [Tue Feb 26 17:53:48 UTC 2019] (Thread-2228) MWA_PH_INIT_CLIENT_FAIL: Fail to initialize client. Disconnecting it now. java.net.SocketException: Broken pipe (Write failed) at java.net.SocketOutputStream.socketWrite0(Native Method) at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:115) at java.net.SocketOutputStream.write(SocketOutputStream.java:140) at oracle.apps.mwa.presentation.telnet.Options.sendDo(Options.java:207) at oracle.apps.mwa.presentation.telnet.Options.startNegotiation(Options.java:160) at oracle.apps.mwa.presentation.telnet.ProtocolHandler.run(ProtocolHandler.java:540)
According to Oracle, these warning messages are because of F5 configuration.
  • Hi, what is the monitor applied to pool?
    It seems it’s a tcp monitor with 5 sec interval which close the connection when it success...
  • SWJO's avatar
    SWJO
    Hi
    your application server seems Oracle.
    I recommend using ORACLE monitor.
    Oracle monitor didn`t close session that is proper than TCP monitor(close session).
