Issue while saving Irule
Hi all, We have created irule but once we saving the irule it is showing error message as : showing error the requested object name /common/ is invalid
Do we require any special thing while saving irule.
- Nazir_52641
Cirrus
Hi Deepak,
Share the iRule and the actual error you got. - Deep_287674
I will try to take snapshot for that , but do we require any license for Irule
- IainThomson85_1
Cumulonimbus
No License.
Looks like you're referencing something that doesn't exit.
In your iRule can you ensure the Common partition is in the correct case ? ( /Common/
- TayF5un
you should correct the object name. for example your object is NAME, but you define it as Name.
- Deep_287674
Iain , as per my knowledge it does not require license for Irule. But , I had word with F5 and they are telling require GTM License. Temporary we have got trial GTM license for 45 days . Hope if this will work after rebooting device.
