ISP with two links browsing
Hi! if i have two differents ISP links, i need perform a snat translation with a snatpool in a particular host, and that my snatpool contains one IP on ISP1 and one IP on ISP2. that is possible?
Example:
ISP1: 100.100.100.1 ISP2:200.200.200.1
Internal 10.10.10.10 SNAT ISP1 100.100.100.10 and 200.200.200.10
the host can reach internet through both isp links with the snat pool indicated
before i did this, but i had some troubles with the persistence.
Regards!
- stan_piron
Cumulonimbus
of course you can do this.
you have multiple solution:
- create a dedicated VS with destination 0.0.0.0/0 and source 10.10.10.10. define SNAT pool on this VLAN
- create an irule to assign SNAT pool based on the client IP
- create an irule to assign manually SNAT
when you assign a SNAT Pool to a VS or with an irule, the pool member is selected based on the egress interface self IP network. so solution 1 or solution 2 are the best
the irule can be:
when CLIENT_ACCEPTED { if {[IP::remote_addr] equals "10.10.10.10"} {snatpool SNATPOOL10} }
