Christopher_J_B
Sep 24, 2010Is it possible to collect HTTP payload information with SSL/Client side enabled on the VIP?
I am creating iRules to parse HTTP Post requests/XML pulling web services call, information, etc.. The method I am using to collect/parse the HTTP payload is not working with SSL termination on the F5 (SSL Profile/Client enabled).
Is it possible? If so which event should I use?
For non-SSL terminate connections using HTTP_REQUEST_DATA using a HTTP:payload function
Here are snippets of the configuration of the VIP
virtual sandapcspapl-ssl-vip {
snat automap
pool sandapcspapl-80
destination 10.12.0.101:https
ip protocol tcp
rules
tcp_CSPRTAPL
xml_CSPRTAPL
profiles
http-x-forwarded-for
sandapcspaplv2
tcp
profile clientssl sandapcspaplv2 {
defaults from clientssl
key "sandapcspaplv2.key"
cert "sandapcspaplv2.crt"
- hoolio
You should be able to use HTTP::collect and HTTP::payload with a virtual server that accepts encrypted SSL traffic and decrypts it with a client SSL profile. The HTTP related iRule functionality should work the same with a client SSL profile and encrypted traffic as unencrypted traffic without a client SSL profile.
Can you post the iRule(s) you're testing and more detail of what you're trying to accomplish versus what's happening?
Thanks, Aaron - Christopher_J_B
I have 2x VIP - one SSL terminated and the other not. The iRule is the same for both VIP - all traffic that is dest'd to the non-SSL VIP works - SSL nada
if { [HTTP::method] ne "POST" } {
event disable all
return
if { (not [HTTP::header exists "Content-Length"]) or ([HTTP::header "Transfer-Encoding"] contains "chunked") } {
event HTTP_REQUEST disable
event HTTP_REQUEST_DATA disable
event HTTP_RESPONSE disable
set http_request_time [clock clicks -milliseconds]
set uri [HTTP::uri]
HTTP::collect [HTTP::header Content-Length]
when HTTP_REQUEST_DATA {
if { [HTTP::uri] contains "csp-authentication" } {
set id [findstr [HTTP::payload] "systemId>" 9 " if {$id contains "IVR"} {
set call [string trim [findstr [HTTP::payload] "" 20 "xmlns="]]
set output "CALL=$call SYSID=$id"
} elseif {$id contains "MYCRICKET"} {
set call [findstr [HTTP::payload] " set output "CALL=$call SYSID=$id"
set output "SYSID=$id"
} elseif { [HTTP::uri] contains "csp-apl" } {
if { [matchclass [IP::client_addr] equals $::net_internal] }{
set tmp [findstr [HTTP::payload] "<" 16 ":"]
if {$tmp contains "ns1"} {
set call [findstr [HTTP::payload] " set output "CALL=$call"
} elseif {$tmp contains "ns0"} {
set call [findstr [HTTP::payload] " } else {
set output "CALL=UNKNOWN"
set tmp [findstr [HTTP::payload] "" 21 ">"]
set tmp [findstr [string map {" " "" "\n" ""} [HTTP::payload]] "" 21 ">"]
set output "CALL=$tmp"
HTTP::release
when HTTP_RESPONSE {
set response "POOL=[LB::server pool] NODE=[LB::server addr] STATUS=[HTTP::status] RESPONSETIME=[expr [clock clicks -milliseconds] - $http_request_time]"
when CLIENT_CLOSED {
if { [info exists output] and [info exists response] } { log -noname 10.66.48.45:514 local0.warning "DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=XML SRC=[IP::client_addr] DST=[IP::local_addr] URI=$uri $output $response" }
Here is a sample of working output
Sep 27 13:25:19 10.3.0.61 tmm[1871]: DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=TCP SRC=208.45.140.93 SRCPORT=40257 DST=10.12.0.101 DSTPORT=443 OPEN=92502
Sep 27 13:25:19 10.3.0.61 tmm[1871]: DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=XML SRC=208.45.140.93 DST=10.12.0.101 URI=/csp-apl/APL CALL= POOL=sandapcspapl-80 NODE=10.12.18.18 STATUS=500 RESPONSETIME=387
Sep 27 13:25:25 10.3.0.61 tmm[1871]: DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=TCP SRC=199.38.44.8 SRCPORT=53430 DST=10.12.0.101 DSTPORT=80 OPEN=614
Sep 27 13:25:25 10.3.0.61 tmm[1871]: DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=XML SRC=199.38.44.8 DST=10.12.0.101 URI=/csp-apl/APL CALL=getCustomerInformation POOL=sandapcspapl-80 NODE=10.12.18.16 STATUS=200 RESPONSETIME=416
Sep 27 13:25:25 10.3.0.61 tmm[1871]: DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=TCP SRC=199.38.44.8 SRCPORT=52511 DST=10.12.0.101 DSTPORT=80 OPEN=181
Sep 27 13:25:25 10.3.0.61 tmm[1871]: DEVICE=SANPRODF5 ENV=PROD APP=CSPRTAPL COMMENT=XML SRC=199.38.44.8 DST=10.12.0.101 URI=/csp-authentication/CSPAuthenticate CALL=createSession SYSID=IVR POOL=sandapcspapl-80 NODE=10.12.18.17 STATUS=200 RESPONSETIME=31 - hoolio
So nothing gets logged at all when you add this iRule to a virtual server with a client SSL profile enabled? Can you add some debug logging to CLIENT_ACCEPTED to check that the TCP connection from the client to the SSL VS has been established and in HTTP_REQUEST to see whether the criteria for collecting they payload is being met?
Also, you should add logic to prevent the iRule from trying to collect more than 4Mb of data as this will cause TMM to crash. You can check this solution for details:
SOL6578: TMM will crash if an iRule collects more than 4MB of data
http://support.f5.com/kb/en-us/solutions/public/6000/500/sol6578.html
And here is an example of restricting the payload collection:From: http://devcentral.f5.com/wiki/default.aspx/iRules/CreditCardScrubber.html Only check responses that are a text content type (text/html, text/xml, text/plain, etc). if { [HTTP::header "Content-Type"] starts_with "text/" } { Get the content length so we can collect the data (to be processed in the HTTP_RESPONSE_DATA event) Limit collection to 1Mb (1048576 minus a little to spare) - See SOL6578 for details if { [HTTP::header exists "Content-Length"] } { if { [HTTP::header "Content-Length"] > 1048000 }{ Content-Length over 1Mb so collect 1Mb set content_length 1048000 } else { Content-Length under 1Mb so collect actual length set content_length [HTTP::header "Content-Length"] } } else { Response did not have Content-Length header, so use default of 1Mb set content_length 1048000 } Don't collect content if Content-Length header value was 0 if { $content_length > 0 } { HTTP::collect $content_length } }
Aaron
