IRules mobile redirects help
I am stuck with particular type of redirects, what I need to do is ..
say a user request
abc.com/acd/dder/dr1-dc2-1245/ or http://abc.com/adv/dcb/34567/
from mobile device, so I want to take last portions numrics out
like 1245 in first URL and 34567 in second URL, and redirect it to something like site?gid=1245 or 34567
last digits are not limited with only 4 or 6 it can be abything, just numbers after - or after / .. I am unable to find out a way to do it ..
and if last digit is not numbers then just redirect to m.site.com
Please let me know if anyone can help out with it ..
Regards,
Ruchir
- hoolio
Hi Ruchir,
Can you provide a few more examples of the URIs you want to redirect to the mobile site?
If the digits are present are they always in the third subdirectory of the path? Is it always a format like // // /letters/ /letters/? Or are there other formats?
Aaron - Ruchir_76829
there can be many format, what we need to capture is digits from last and break point is either - or /
so if URI end is /234567/ - then ID = 234567
if URI last is /ar1-br2-cr3-3456/ then ID=3456 - hoolio
So it's always the last subdirectory that you want to parse? And are the digits always on their own // or // or following a hyphen like this /AAA-AAA-AAA-/ or /AAA-AAA-AAA-/?
If so you could try something like this example. Note that I haven't fully tested it. So if you see any issues can you reply back with the debug from /var/log/ltm?when HTTP_REQUEST { Get the index of the last URI directory set depth [URI::path [HTTP::uri] depth] Parse the last directory in the path set last_dir [URI::path [HTTP::uri] $depth $depth] Parse everything after the last hyphen in the last directory set digits [string trimleft [string range $last_dir [expr {[string last - $last_dir]}] end-1] -/] log local0. "URI=[HTTP::uri], \$depth=$depth, \$last_dir=$last_dir, \$digits=$digits" Check if we parsed 4 or 6 digits switch $digits { [0-9][0-9][0-9][0-9] - [0-9][0-9][0-9][0-9][0-9][0-9] { Found 4 or 6 digits, send a redirect HTTP::redirect "http://m.site.com/test/?gid=$digits" } } }
It would be more efficient if you could only perform this URI parsing for specific requests that might have the GID in the path. Do the requests always start with a standard path? Or is there another way that you could limit when you check for the 4 or 6 digits?
Aaron
