Justin_18188's avatar
Justin_18188
Sep 18, 2008
iRule variable problems
I have an iRule that captures the SSL client DN and places it in a variable to be passed to an application. 98% of the time, there is no problem. But 2% of the time, user's CN get crossed. One person will have a different person's CN on their page. Any ideas? Is this most likely a caching issue where a user views a page and it gets cached, and someone else views the same page and see the other person's cached version?
  • No, we are using a TCP profile with a few settings changed. I'll put it all out there though:
    Reset on Timeout - enabled
    Time Wait Recycle - enabled
    Delayed ACKs - enabled
    Proxy Maximum Segment - not checked
    Proxy Options - not checked
    Proxy Buffer Low - 98304 bytes
    Proxy Buffer High - 131072 bytes
    Idle Timeout - 300 seconds
    Time Wait - 120000 seconds
    Fin Wait - 5 seconds
    Close Wait - 5 seconds
    Send Buffer - 65535 bytes
    Recieve Window - 65535 bytes
    Keep Alive Intreval - 1800 seconds
    Max Syn Retransmissions - 3
    Max Segment Retransmissions - 8
    IP ToS - 0
    Link QoS - 0
    Selective ACKs - Enabled
    Extended Congestion Notification - not checked
    Extensions for High Performance - enabled
    Limited Transmit Recovery - enabled
    Slow Start - not checked
    Deferred Accept - not checked
    Bandwidth Delay - not checked
    Nagle's Algorithm - not checked
    Acknowledge on Push - enabled
    MD5 Signature - not checked
    MD5 passphrase -
    Congestion Control - New Reno
    Congestion Metrics Cache - enabled
    Appropriate Byte Counting - enabled
    D-SACK - not checked
    This is in use with a BEA application and was configured by some people that never worked with anything F5 before.
  • when CLIENTSSL_CLIENTCERT {
    set ssl_cert [SSL::cert 0]
    set id [SSL::sessionid]
    session add ssl $id $ssl_cert 900
    when HTTP_RESPONSE {
    if { [info exists certStr] } {
    HTTP::header insert "Set-Cookie: ClientZ=$certStr; Path=/"
    if { [info exists ssl_dn] } {
    HTTP::header insert "Set-Cookie: SSL_CLIENT_DN=$ssl_dn; Path=/"
    set my_uri [string tolower [HTTP::uri]]
    if {( $my_uri starts_with "/console") || ($my_uri starts_with "/soafportalwebproject")} {
    if {! [HTTP::cookie exists ClientZ] } {
    set cert [session lookup ssl $id]
    if { $cert ne "" } {
    set certStr [X509::whole $cert]
    set ssl_dn [X509::subject $cert]
    remove unwanted formatting.
    regsub -all "\n" $certStr "" certStr
    set certStr [string trimleft $certStr "-----BEGIN CERTIFICATE-----"]
    set certStr [string trimright $certStr "-----END CERTIFICATE-----"]
    if certStr is blank...
    if { $certStr equals "" } {
    log local0. "no certStr... Deleting Session 11"
    session delete ssl $id
    set certStr [HTTP::cookie ClientZ]
    if { $certStr ne "" } {
    HTTP::header insert WL-Proxy-Client-Cert $certStr
    HTTP::header insert WL-Proxy-Client-Keysize 128
    HTTP::header insert WL-Proxy-Client-Secretkeysize 128
    if { $ssl_dn ne "" } {
    HTTP::header insert SSL_CLIENT_DN $ssl_dn
    HTTP::header insert WL-Proxy-SSL true
    HTTP::header insert WL-Proxy-Client-IP [IP::client_addr]
