Irule using a data group to bypass header injection
Trying to do a basic irule that looks at a data group and bypasses the header injection based on the data group uris. Been messing with the below but getting multiple errors when adding the top lines to bypass the existing irule posted below. Datagroup would be the uribypass
if { ([class match [HTTP::path] starts_with "uribypass"]) } {
exit
else {
if { !([HTTP::header exists "test-Proxied" ]) } {
HTTP::uri /test[HTTP::uri]
# Inject custom header
HTTP::header insert test-Proxied 1
- JRahmAdmin
Hi jcarpenter82
You are close, but missing a closing bracket on the first if statement, and you want return, not exit there. I think this is what you're after:
when HTTP_REQUEST { if { !([class match -- [string tolower [HTTP::path]] starts_with uribypass] || [HTTP::header exists "test-Proxied"]) } { HTTP::uri "/test[HTTP::uri]" HTTP::header insert test-Proxied 1 } }
