Fletcher_Cocquy's avatar
Fletcher_Cocquy
Mar 13, 2007
iRule to help WebDAV COPY work through SSL Proxy
We are migrating webdav publishing services to BIG-IP 9.1.2 Build 40.6
We are seeing error 502, on COPY operations and other operations not functioning correctly through the SSL proxied virtual.
It sounds like this is a malfunction of the proxy according to the posts I found from the SVN users list:
http://svn.haxx.se/users/archive-2006-12/0946.shtml
“The proxy only rewrites the request URL, but not the other headers, so the
SVN-Apache (Apache without SSL) receives:
COPY /svn/old/path HTTP/1.1
Host: svn.myserver.tld:10600
Destination: https://myserver.tld/svn/new/path
...and immediately recognizes that it is definitely not responsible for
serving https, let alone myserver.tld or even port 443. So it does not show
the the request to SVN, but instead sends back a 502 error.
(I found that with the help of tcpdump, LogLevel debug and a good long look
into the mod_dav sources.) “
Has anyone solved this with an iRule?
I don’t want to hack mod_dav as one user did.
Relevant config:
virtual irt-publish-ssl {
destination a.b.c.d:https
fallback persist source_addr
ip protocol tcp
profile irt-publish sslheader tcp
persist ssl
pool irt-publish
profile http sslheader {
defaults from http
header insert "GOHTTPS:1"
redirect rewrite all
insert xforwarded for enable
Thanks,
Fletcher.
