Kalpesh_48932
Oct 29, 2014Irule to delete persistence entry for node which is marked down by F5
I want to implement irule which can delete persistence table for particular pool member when it will be marked down by F5.
- mikeshimkus_111Historic F5 Account
Hi Kalpesh, BIG-IP shouldn't forward a new connection to a pool member that's marked down, regardless of whether or not it matches a persistence entry. I don't think you can manipulate the persistence table through iRules.
