kgaigl's avatar
kgaigl
3 years ago
IRule to block URL/URI from Data Group
Hello,
we've a VS with about 20 URLs, now I've to block Login-Sites dor the most but not all URL's, for eg:
www.somesite1.org/login
www.somesite2.org/member
www.somesite2.org/login
I'd like to put all the Adresses (about 30-40) in a Data Droup List with strings and reference this List in a IRule with a Respond like "HTTP::respond 403"
Could you help me with a Syntax? Should be Case insensitive.
Thank you
  • here is an example:
    ltm data-group internal example_uri {
    records {
    login { }
    member { }
    type string
    if {[matchclass [string tolower [HTTP::uri]] contains example_uri]}{
    HTTP::respond 403 content "You don't have authorization to view this page. Access Denied" noserver Content-Type text/html Connection Close Cache-Control no-cache
    log local0. "deny URI: [HTTP::uri]"
  • kgaigl's avatar
    kgaigl
    Hi  mihaic,
    thank you, but I need always the combination of [HTTP::host] and [HTTP::uri], becaus on some hosts the URI "login" should be allowed.
    I guess the Data Group file I can manage, but the Syntax of the combination [HTTP::host] and [HTTP::uri] I'm not shure
  • when HTTP_REQUEST {
    if { ([HTTP::host] == "www.xyz.com") and ([matchclass [string tolower [HTTP::uri]] contains example_uri]) }{
  • kgaigl's avatar
    kgaigl
    Hi mihaic
    with
    if { [class match [string tolower [HTTP::host][HTTP::uri]] equals BLOCK_LOGIN_SITES] } {
    HTTP::respond 403
    it's working
    thank you
  • Hi kgaigl ,
    this should work. Note that I'm not putting URI in lowercase so /login and /LOGIN will require two different matches (they would be two different URLs indeed anyways)
     set req "[string tolower [HTTP::host]][HTTP::uri]"
     if {[class match $req eq unallowed_datagroup]}{ HTTP::respond 403 }
    ltm data-group internal unallowed_datagroup {
        records {
            www.somesite1.org/login { }
            www.somesite2.org/member { }
            www.somesite2.org/login { }
        type string
