Aziz-90s's avatar
Aziz-90s
Dec 05, 2022
Solved
irule block uri for external users when url has special characters such as $
Hi all
I've tried an irule on VIP for the website example to block the uri for external users only example /_api/$metadata I need to block this path /_api/$metadata
so what I tried is
When HTTP_REQUEST {
    if { [HTTP::host] equals"example"} {
       if {[string tolower [HTTP::uri]] starts_with "/_api/$metadata" }{
   if {  not ([class match [IP::remote_addr]  equals private_net]) }{
# reject
Noting a couple of things
1/ when I applied it the web went down even though the REJECT is written as a comment in the irule
2/ there are two policies a WAF policy & redirect policy applied to VIP so I thought it might be the reason, I removed the policies  and tried irule same results web went down even when reject is a comment
besides I really wants to use irule, i red that we can use policy but never tried. I'd love to know my mistakes in irule
can anyone tell me what i missed and if could explain why
thanks
  • Hi Aziz,
    Two things that I noticed in the iRule;
    1. there is no space between equals"example"} - although I suspect this is just an edit error for the question here, I thought I'd mention it, just in case... 😉
    2. "/_api/$metadata" - are you referring an iRule variable or is this part of the actual URI? If it is a variable, where is it exactly declared? If part of the URI, the iRule will probably think it's a variable and interpret as such. To avoid this behaviour, try putting a backslash in front of it to clearly tell the iRule to take is as its literal value. ( "/_api/\$metadata" )
    If the above two things didn't help, did you see any messages in the ltm log? (/var/log/ltm) and what is the behaviour when connecting from inside a private net or outside? Lastly, any chance of any proxies in between that are always hiding behind an outside address?
    Regarding Local Traffic Policies; yes, they are brilliant and often a great replacement for basic iRules (...but iRules are still awesome!). I think your example might indeed be a good one for an LTP. Have a look here: https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/local-traffic-policies-getting-started-12-1-0/1.html but also just give it a go in the F5 GUI and you'll be able to figure it out quickly. (go to Local Traffic - Policies - Create new policy)
    Hope one of these tips helps.
    Alex
  • Hi Alex
    Thanks for replying
     The /_api/$metadata is part of uri,
    also I forgot to mention that I did a little research about special characters in uri
    and it turns out that we could somehow avoid or resolve this issue by using a syntax Set_encode something like that
    have u hear any thing like this.
    I'll try ur suggestions & reply back
    much appreciated
  • Hi Aziz,
    Alex
    • Aziz-90s's avatar
      Aziz-90s
      Hi Alex
      Thanks for replying
      much appreciated
      • PeteWhite's avatar
        PeteWhite
         if {[string tolower [HTTP::uri]] starts_with {/_api/$metadata} }{
