Tomasz_93254's avatar
Tomasz_93254
15 years ago
Irule strange problem
I have the following Irule on my LTM F5:
set subpath [HTTP::uri]
if {[HTTP::host] equals "aaa.co.uk"} { HTTP::respond 301 Location "http://www.aaa.co.uk$subpath" }
elseif {[HTTP::host] contains "www.aaa.co.uk"} {use pool pl_it_www-aaa-co-uk_p80 }
elseif {[HTTP::host] contains "www.aaa.com"} {use pool pl_it_www-aaa-com_p80 }
elseif {[HTTP::host] equals "bbb.com"} { HTTP::respond 301 Location "http://www.bbb.com$subpath" }
elseif {[HTTP::host] equals "www.bbb.com" and [HTTP::uri] contains "/qqq"} { HTTP::respond 301 Location "http://www.bbb.com" }
elseif {[HTTP::host] equals "www.bbb.com" and [HTTP::uri] contains "/default.html"} { HTTP::respond 301 Location "http://www.bbb.com" }
elseif {[HTTP::host] contains "www.bbb.com"} {use pool pl_it_www-bbb-com_p80 }
The rule works fine but only if there is a default pool associated in virtual server configuration. If I change this Default Pool to None from the drop down, the Irule stops working. Any obvious reasons why it happens?
BRs
  • hoolio's avatar
    hoolio
    Can you try this? It's explicitly setting the pool or redirect for each case.
    when CLIENT_ACCEPTED {
        Save the VS default pool name
       set default_pool [LB::server pool]
       switch [string tolower [HTTP::host]] {
          "aaa.co.uk" { HTTP::respond 301 Location "http://www.aaa.co.uk[HTTP::path]" }
          "www.aaa.co.uk" { pool pl_it_www-aaa-co-uk_p80 }
          "www.aaa.com" { pool pl_it_www-aaa-com_p80 }
          "bbb.com" { HTTP::respond 301 Location "http://www.bbb.com[HTTP::path]" }
          "www.bbb.com" {
             switch -glob [HTTP::path] {
                "*/qqq*" { HTTP::respond 301 Location "http://www.bbb.com" }
                "*/default.html" { HTTP::respond 301 Location "http://www.bbb.com" }
                default { pool pl_it_www-bbb-com_p80 }
          default {
             pool $default_pool
    Aaron
  • I have tried this and the script is not working either. NOnetheless I think I found the root of the problem.
    When I did debugging:
    log local0. " URI: [HTTP::uri], Host: [HTTP::host] ,Path: [HTTP::path]"
    Sample log shows:
    URI: http://www.bbb.com/aaaa, Host: ,Path: http://www.bbb.com/aaaa
    HTTP::host for some reason is not set, which is most probably the reason none of the if statements were matched.Any idea why HTTP::host is empty? How can I obtain the host which should be www.bbb.com?
