Deepak__M_K_165
Aug 14, 2014iRule redirection issue
Hi All,
I have a redirection rule applied on F5 -LTM -9.2.3 version . This is to redirect "www.webserver.com" to "https://webserver.com" some how there is an intermittent issue. Not sure if this version of F5 support this kind of iRule.
when HTTP_REQUEST { if {[HTTP::host] eq "www.myserver.com"} { HTTP::redirect "https://myserver.com[HTTP::uri]" } } Much appreciate the input
Hi
Try making it case insensitive:
when HTTP_REQUEST { set host [string tolower [HTTP::host]] if { $host eq "www.myserver.com"} { HTTP::redirect "https://myserver.com[HTTP::uri]" } }/Patrik
- Deepak__M_K_165
Hi Patrick,
Thanks.Will be testing it by next week. Will let you know the result.
- What was the actual issue? I assumed it did not run, but maybe it's something else?
