Redirection with datagroup and irule
Hello teams,
Need helps!!
I want to redirect a host in terms of path
example: xxx.com/abc/jlk to xxx.com/aze, xxx.com/wyc/jlk to xxx.com/aze, xxx.com/oic/jlk to xxx.com/aze .......
For this i want use the datagroup with irule: i created the datagroup that contains all path that i want to redirect.
I also tested with policy LTM but this method works on some browser and not for all path.
So i want use the Irule for this, can you help me pleasee!!!
thank you!
Hi mika,
If datagroup values contain upper case, replace them. iRule:
when HTTP_REQUEST { if { [class match [string tolower [HTTP::uri]] equals dg-name] } { HTTP::redirect "https://xxx.com/aze" } }
You can use starts_with instead of equals according to your needs.
Hi mika,
- mika
Cirrus
thank you
